LifeSpan 1200i board fuse pops when switched on
I think I caused this problem when I turned on my treadmill and accidentally hit the breaker reset switch at the same time as the power button. Everything came on for a second then the power shut down. The fuse on the board where the power enters had popped and the house breaker also tripped. I replaced the bad fuse but now every time I turn of the power it beeps like it is going to turn on then the fuse pops again. I am wondering if a bad breaker reset switch could cause this problem since that is what I hit by accident and may have damaged?
