Pro-form 925 CT
                    I cannot find the answer to this anywhere. The problem is that the top of the treadmill by the front roller is the part that keeps tracking all the way to the left when I get on it. At one point the belt started grinding all the way to the left. The belt is almost a little diagonal from the front roller to the back roller. So if I adjust it so the front doesn't grind to the left t then it comes dangerously close to the back grinding on the right. Then on top of that, if I do done a happy medium, the belt moves to the left when weight is applied. Is there even a way to adjust the front roller on this model?
