Nordictrack X11i belt center issue
This is an incline trainer not a treadmill so I hope im posting in the correct location. I appreciate any advice given.
I purchased this online for $200 so I expected some issues. The belt adjustment in the front of the machine works great and everything is centered there. My issue is at the rear of the machine. The belt tracks to the runners left side only in the rear. The roller in the rear only has one adjustment screw on the left side and pivots from the right side. This adjustment screw also looks to be tensioning the drive belt. I have this tightened all the way (tightening the belt) which looks like the logical approach to move the belt back to the right (center). The belt is not really rubbing but very close. It basically is running on an angle which definitely is not right. Any thoughts?
Could the adjusting bolts in the front move the belt in the rear as well? From what I read those only adjust the belt position at the front of the machine. I cannot get this centered no matter what I do. Just thought there may be a trick to it.
Thanks for the reply!!
