NordicTrack 2900 elite front roller detachment
Purchased a new walking belt from you guys and will be getting this Tuesday. Looking at the front roller there are no bolts. How do I remove front roller? See image, thank you!
  • You should able to slide roller over to one side enough to pop out roller.
  • Thank you! Was trying to research before getting into it. I kind of figured that once I relieve tension of the walking belt and drive belt I would be able to slide to one side. Didn't see anything on google search regarding this type only able to find bolt in front roller procedure. Hope this will help somebody else, Thanks again.
