Console cycles on and off - Proform 2500 PFTL4972
Unit all of the sudden will will turn on and then the console will cycle on on off continuously. I have unplugged the unit and let it sit, always seem to help when I copier business, but it still will not come out of this cycle. I reseated the connections under the hood, and still no change. I did notice that each time the unit cycled, I could feel the incline motor thump slightly.
Anyone else experience this? I am guessing that there is some way to get a error code off this, and if so any guidance would be great on how to do this, along with a cross reference to the error.
Thanks in advance,
Brad
Thanks in advance,
Brad
www.treadmilldoctor.com/icon-calibration-instructions-mc-60
I followed the instructions, but as soon as I press the incline button in step 3 I get the flashing console. It is really strange, at one point last night, it finished cycling the incline motor and came to ready. There was a little flicker on the console run I got it to run for a few minutes. Once I stepped on and turned it to 3, it shut down and started the flashing console again.
Thinking it may be the incline motor, I removed the motor and was able to turn it freely by hand. Using a drill, I could get the actuator to move as well. I even tried turning on the unit with the motor removed, but plugged in with no change.
Do you have any other thoughts?
