Treadmill Shuts Off
Hi, I purchased a used preform and when I got home and plugged it in, everything on the console lit up but as soon as the belt started to move, it shut the entire thing down. You can press the reset button and it does the same thing, starts to work but as soon as the belt turns it shuts off. Any ideas if this is a cheap fix?
  • Does it just trip the breaker on treadmill or does it trip breaker in house, If the breaker in house is a GFI circuit. Most treadmills can not run on a GFI circuit.
