Gold's Gym Treadmill CrossTrainer 600 Belt stops when attempting to run on it.
I got this treadmill from someone else. I've looked online to try to determine the issue.
1). I've lubricated the deck with lubricant using the wand applicator which hasn't helped.
2). With the motor cover off. Stepping on the Belt causes the treadmill rollers to stop, and drive belt to stop.
3) With the Incline to 10, the belt does seem to run better and not stop while running/walking on it.
4) I attempted to stop the flywheel with a stick, but couldn't slow it down.
5) the Belt runs smoothly and no stutters or anything when no one else on belt.
Does it seem more so the belt, than anything else?
I inspected the belt and it doesn't seem bad or appear to be fraying, but it could be 2 years old or older i'm guessing.
So when I step on the belt(F) and stop it. The Front Roller (E) stops, as does the Front Roller Pulley(A) and the Drive Belt (D). The Wheels (B) and (C) continue to Spin. There's Squeaking from friction at (G), i believe, when I stop the belt.
and by tightening the Drive belt, I'm assuming that means moving/adjusting the front roller position?
when I run on the running belt, occasionally it will get "stuck" like a "stutter". I've lubricated the Deck.
I'm debating whether the Drive Belt needs to be tightened a little more as i tried to do it myself and The Gold's Gym motor is set up so you have to step on it to increase tension on the belt OR the running belt itself is going bad and just needs to be replaced. I've tried to inspect the running belt, but it doesn't seem to be bad underneath in comparison to pictures i've seen on the internet.
