Schwinn 870 Console
I bought a Schwinn 870 used I verified everything worked. I had to take it apart to get inside of my house, once I had everything together again I turned the console on and all it shows is “ dd d:dd dd:dd” in the top display section. Down in the main screen it has one “-“ in the middle right of the screen. The incline works I can automatically raise and lower but nothing else is working on the console. I unplugged everything again and made sure the connections are good it still does the same thing. I opened it up to the MCB when I turn it on the power LED is lit, and the info LED is lit solid at first, then something clicks and the info LED will start blinking. Is my console screwed or am I missing something?
Idk if this is something else entirely but the treadmill is rated for 120 volts 15 amps, I did notice the power cord the seller gave me is 125 volt 10 amps. If that affects anything please let me know.
