Norditrack 2450 won’t power up
Hi. I hope you can help me please. I have a Norditrack 2450 commercial treadmill it’s about 8 years old.When I turn it on a fixed red light comes on the lower control board but the console won’t light up and the machine won’t work at all.Just below the console their is a small circuit board that has the words ant/ receiver.It blinks 4 times stops and then continues to repeat that process.The machine has a reset switch that seems to work.I look forward to hearing from you.Thank you Phill
  • The best way to see which is bad, either console or controller is to test the main harness that runs up the right side. You want to check for 8 to 12VDC with a voltmeter between the red wire & the black wire. If you have the proper voltage then you have a bad console, but if you do not have that voltage then its a motor controller.
  • Thanks very much for your help.I will test that out👍🥸
  • Let us know how you make out.
