AFG 2.5AT Beep codes
Hi,
On initial power up the treadmill has one long beep and two short. System has lights but unresponsive. Toggle power, 3 short beeps, everything normal. New oddity recently, 30 seconds into use the drive motor stops as though the safety were pulled but it has not. Display normal. Start gets it going again. Suggestions for repair? Know what the beep code sequence means?
Thank you,
Doug
