Proform 2000 squeaking from either the drive belt or roller
Hello all - I'm hoping to get some help with a squeak from either the drive belt or the roller. I've pinpointed the noise with the cover off after my routine maintenance/cleaning. It's got 1250 lifetime miles on it as of this posting.
The squeaking is quite rhythmic & at first I assumed it was the walking belt, which I lube up around once a month. I also adjusted the rollers/belt tension and it's still present. It's definitely in relation to the speed of the belt as well.
The squeaking starts as soon as the treadmill starts. It used to only last for around 30-45 seconds and then went away. However, now it's present for approximately 4-5 minutes before it stops.
I've included a link to a video I posted on YouTube of the noise. Hoping I can get some guidance here.
https://youtube.com/shorts/KHt25Fln8_c?feature=share
This forum has been quite helpful for me in the past, as well as Kevin C who emailed me in the past to help. Hoping to get some direction so I can make another repair and put some more miles on my treadmill.
