So - Nordic 1500CM - front roller fix - did I screw it up or is there something new?
Hello:
NordicTrack 1500CM
The front belt was came off and I noticed the plastic pulley on the front roller had slid way over. After consulting Treadmill Dr. and Youtube I decided to take a mallet and tap it over. Then I drilled four holes right down the center of the pulley and screwed in some recessed screws afterwhich I epoxied them in place.
The intent was to stop the pulley from shifting in the future and the screws were glued into place to stop them for coming lose.
Now - when I used the machine, the speed is way off - often too fast. It fluctuates up and down. The display reading fluctuates or reads zero at low speeds 2mph-4mph (I cant remember what happens at fast speeds=6mph+). I went into calibration mode and that didnt work - mainly because I couldnt find details on what everything does.
I didnot mess with the controller board or its potentiometer. (All I did was vacuum the dust out the whole main area)
So - Im wondering if the screws (which were metal) are messing up the speed sensor and I need a new roller - or do I have a symptom of another problem all-together.
Thanks for reading.
-Froggy
NordicTrack 1500CM
Thanks for reading.
-Froggy
Thanks for your help.
