Nordictrack commercial 2950 belt bogging down
Hello all. Just this week, my belt began to bog down a I started my run. It had not been used for a few days. I then tried at a lower speed and attempted at 3mph and same thing. I started troubleshooting using some recommendations from this forum's youtube channel to see if it's the motor and at this point I am unsure. When I put the treadmill at 3 mph and stop the belt with my foot, both the flywheel and roller stop. I have also lubricated the belt and platform as well as attempting to tighten the belt a bit. Same results. Any recommendations or suggestions for me to troubleshoot? I know this unit does have a lifetime warranty on the motor if that is the issue. Your help appreciated.
Here is a link to the controller; https://www.treadmilldoctor.com/nordictrack-commercial-2950-motor-control-board-ntl221140-399610
and Here is a code you can use on the checkout page for a 10% discount (10offkevin)
Just want to confirm before I purchase a board and the issue remains after replacement. Thanks again
