Nordictrack C990
So my son has deleted iFIT app from my treadmill and now I only have the android screen and none of the functions will work. I'm guessing I need to reinstall the software and have no idea how? I keep reading that I should try a factory reset and it asks me to find the reset button and use a paperclip, the problem is that I can't find it? The only reset is the rocker switch where the power cable enters the treadmill. It says off and reset. Any suggestions would be much appreciated. Thank you
  • There is no reset on this machine for the console. You'll have to reach out the manufacturer to see if they have a way to reinstall the app. Usually when this happens, the whole console is replaced.
  • Thanks for the reply, sounds like a potentially expensive job for just for a software install. I'll contact Nordictrack and see if they can help me out.
  • how did you go with the software ?
  • I ended up ordering a micro sim from the states. Cost me a fortune for delivery which took 3 weeks! All working fine now though :-)
  • That's great. I've seen a lot of people try this with no luck.
