Nordictrack 1750 motor board trouble
Hey, my Nordictrak commercial is giving a brief burst of power when I try to start a run, the red LED is giving 3 flashes followed by a pause then another 3 flashes and so on. From what iv seen online this means the motor board is receiving over 34 amps and the board needs to be replaced🤷🏻♂️.
Also I buy from treadmill doctor but it turns out not to be the problem can the board be returned?
Thanks for any help.
Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in. Use this code 1982 at checkout for a 5% discount on your order.
