Epic View 550/700 Endcap
How do you remove the Endcap on the Epic View 550/700 treadmill? I need to replace the roller. I see a bolt/screw on the rollers, but I don't think that's it. On the back/rear of the endcap, there's a hole which has a bolt/screw but it's doesn't seem to be attached/holding to the endcap in any way.... since it's a hole in the endcap....
Screw 56 doesn't touch the parts (54,59). There's a hole in 54+59 that the screw just goes completely through. I think the two #56 screws are the belt adjustments (tighten/loosen).
