Live strong LS 8.0t shuts off suddenly.
I’ve been having troubles with my treadmill shutting down while running. I have lubricated the belt. I did take the panel off and got a error light flashes 3 times then a pause. I was going to replace the belt but worried that won’t fix the error and will have to replace the controller board as well. Don’t want to put that much money into it. Do you have any advice?
  • Hello!
    We apologize for the delay in returning your query!
    Here are some tests you can try to test out your treadmill:
    https://www.treadmilldoctor.com/shuts-down-during-a-workout
    If these do not help let us know and we will go from there!
  • 3 blinks is a overload caused by to much current draw from the motor which most likely means that the walking belt is worn out.
    If you purchase a new belt below is a discount code to save 5%
    Discount Code - COPY AND PASTE this code, 1982 in the discount code box for a 5% discount off your order,
  • call me 888-362-1105 then enter Ext 331 and ask for Jim , if you have any questions.
