Need part for Smooth Agile DMT X2i
Need the “limit collar” that goes on the resistance motor - it’s a small plastic piece that has a set screw in it.
Does ANYONE know where parts for this old (2012) machine are located? Any help would be appreciated.
This should solve the 30 second pause issue in unit
1. Please remove the right side pedal arm, the teardrop cover, and the white disc.
2. Then, loosen the set screw on the limit collar of the resistance motor.
3. Slide it all the way up.
4. Power off, then on and then set the collar to 1.25 inches from the top of the collar to the center of the magnet bracket holes.
5. If there isn’t enough room on the shaft to get 1.25 inches, set it at 1.00 inches and power off and then back on. Set to 1.25 inches.
6. Tighten set screw. Then test unit… press start and spin the crank… watch console to see if rpm’s are present
