Nordictrack 1750 not working
So I just bought a used NordicTrack 1750 and when I was with the person I tested the machine that works fine
after disassembly and moving it there is a solid red LED is on the control board and the console is not working .can anyone please provide me with a good passage on what to verify and also to know what the voltage should be
Thanks in advance
Thanks in advance
hopefully you just have a wire loose...
check to make sure all wires are securely plugged in inside
(You need to check for volts DC on the black and red wires for the 8-12V. This is like checking voltage on a battery....as opposed to checking voltage on your wall outlet in your house. The logic board converts from the 120V AC from your wall outlet to the 8-12V DC to go from the logic board to the treadmill motor.)
