NordicTrack SL728
When using IStep programs….the resistance changes at a pre-determined spot.
My problem. The resistance changes on the display but no resistance changes on the pedaling. I removed cover and the friction pad is approximately 1/2” away from wheel. I am suspicious of the tensioning motor and it doesn’t respond when test pedaling. Is there an electrical test to prove the motor is bad? Or is there another problem I might be missing? Thanks
  • You can test to see if you are getting 6vdc at the motor when you give it a command
