ProForm 415, Model# 831.24853.0, Loud Clicking Under the Hood
Hello, my ProForm 415, Crosswalk Fit, MC-2100, Model# 831.24853.0, has recently started with a loud clicking sound under the motor hood. I lifted the hood and the clicking is coming from either the motor area or the belt area on the right side of unit. Under warranty, I had a new motor put in in April, 2020 and has worked fine since. As I listen close, it seems to be clicking as the motor belt turns. Can't tell if it's the actual motor clicking or the motor belt area. With this lax description, can you tell what might cause the clicking and what steps to take to stop the clicking. Thank you!
  • Sounds like the motor, but you can always remove drive belt and see if motor still makes that noise.
