Treadmill won't slow down
After I have set a speed and want to slow it down it does nothing and I'm not certain the incline works, you hear a noise as If it's changing but doesn't feel like your walking uphill. Also sometimes when turn on it auto sets to run for 90minutes. What could be wrong?
If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor.
If that does not help - make sure there is no crimping in the wires...
If you do not have the voltage then the motor controller is bad
