Smooth 5.0 Error E22
I have just replaced the motor control board on this treadmill. I ran the old, LCD calibration procedure. Incline seems to work fine. Speed does not. The motor will start to run for a second or two, then stop. After another 10 seconds or so, the MOT LED goes off and the E22 is displayed in the incline window on the display. The SPD LED blinks as the belt/roller is turned so the encoder seems to be OK.
I have also loosened the walking belt so there should not be any tension on the front drive roller.
Any ideas?
Any ideas?
