LiveStrong 8.0T Treadmill - Potential Controller Board Issue?
Hi everyone,
First time poster here. Have had the LS 8.0T for a number of years now. Was on it a few weeks ago and it stopped suddenly and I thought I had disconnected the safety key but that wasn't the case. I have confirmed motor works using the battery test. The LCD panel lights up and all buttons beep when pressed and seem to be functioning. I put it into "Engineering Mode" based on service manual and can cycle through all the options but when it comes to running the motor test nothing happens. I suspect a bad controller board - there is a single LED on the board that blinks 4 times and pauses, then just repeats that pattern continuously. The treadmill "sounds" fine in that when you power it on the relays click and does the 3 beeps as per normal. Any suggestions greatly appreciated. Thank you.
Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in. Use the code 1982 at checkout for a 5% discount on your order
