sears proform 650e
I get the fast blinking light like its drawing too much power and then it slows to a crawl. I need to get this up and running again.. my life depends on it
.. I've replaced the motor and the little sensor that monitors the walking belt for timing.. I've even used silicone oil to grease the deck.. the only real last thing would be the controller board.. could anyone give me any clue as to whats going on? the belt doesnt seem that tight either.. have you seen bad controller boards causing this problem? really could use some help if anyone has any idea what could be going on.. thank you
