Keys Center G Elliptical Resistance Appears stuck
All of a sudden the resistance is not changing on any of the programs. It appears to be stuck on a high resistance level.
I opened the side panel and can see and hear the resistance mechanism adjusting to higher and lower levels, however there is no actual change in resistance. The belt appears to be in good shape and no debris was found during my inspection.
Any recommendations would be greatly appreciated.
Thanks!
Thanks!
either the resistance motor is not working or the upper console is not sending the voltage down to the resistance motor when you press the up or down buttons,
the only way to check that is get a volt meter and check down on the plus that connects the harness to the resistance motor and see if you have 6-12 volts there
