Epic 550 treadmill - flywheel removal from motor
                    Hello, I have an Epic 550 treadmill that I'm trying to disassemble the motor to install new bearings. Any advice for removal of the flywheel? I've removed the set screw from the end of the shaft on the flywheel side but I'm not able to twist off the flywheel. Any advice is welcome.
You must turn this clock-wise to remove!
