NordicTrack 2155 Starts for 2-3 seconds and shuts off
                    I checked the tension and belt alignment, corrected it and still had same problem. Then I opened the motor bay and disconnected the belt from the roller and belt assembly and it still does the same thing which eliminates the roller assembly being the cause.... Looked for loose wires and air blasted all of the dust out and still the same problem....
Does anyone have any insight? Would it be a controller problem or motor problem? Every time I hit the stop button and then the speed button its starts up right away for 2-3 seconds then shuts off. I want to say every time it starts, its starts pretty aggressively, I would think it should start out more slowly...
https://www.treadmilldoctor.com/shuts-down-during-a-workout
