Nordictrack C1800S Treadmill - Suddenly Stopped - Speed Settings go to Zero - Motor not spinning
                    The treadmill stopped suddenly. The treadmill used to make some noise after using for 30 to 40 minutes and go away. It suddenly stopped one day. Will that be a motor problem? I replaced the drive belt recently, which was almost worn out. The treadmill is about 15 years old and heavily used. The speed setting on the display goes to zero immediately after setting it for any speed. Is that a control board issue? Or, because of the motor is not running? I bought a new motor and try to connect the wires to the board to see whether motor is spinning and it's not. The new motor is not connected permanently to the treadmill. I have to remove the pully from the old motor. I wanted to whether it's control board issue or not first.
Could someone help me to troubleshoot? Thanks in advance.
what is your model number?
888-362-1105 then push 2
