Reset a Livestrong LS10.0T
                    Does anyone know how to reset a Livestrong LS10.0T treadmill? Mine was working just fine and then I unplugged it to move the treadmill. When I plugged it back in it will no longer work. It turns on, beeps three times then does a double beep. The console lights up in what the manual indicates is demo mode. But none of the buttons on the console react anymore. Seems like most treadmills have a hard reset button but I can't seem to find one on this model. Any ideas how to reset this model? Thanks in advance.
If you have a voltmeter you can check to see if you have power going to console on the red wire & the black wire should be between 8 to 12 vdc.
