Livestrong 8.0T Not powering on
I tried to power on my livestrong 8.0T treadmill after a year. It’s not bot starting. I hear the display do on for a second and then turns off, repeatedly.
Hear a click on the circuit board as it’s trying to power on.
What could be the problem?
Debug Trace
| Notice |
#2 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1966): Gdn_Format::tagContent('@admin-it @vipe...', 'Gdn_Format::for...')
#3 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1848): Gdn_Format::mentions('@admin-it @vipe...')
#4 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(878): Gdn_Format::processHTML('@admin-it @vipe...')
#5 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(2198): Gdn_Format::html('@admin-it @vipe...')
#6 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/helper_functions.php(24): Gdn_Format::to('@admin-it @vipe...', 'Html')
#8 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/comments.php(19): writeComment(Object(stdClass), Object(DiscussionController), Object(Gdn_Session), 2)
#14 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/controllers/class.discussioncontroller.php(362): DiscussionController->index(8287, 'x', 'p1')
#15 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.dispatcher.php(845): DiscussionController->comment('1538')
#18 {main} |
Here are some tests you can try!
https://www.treadmilldoctor.com/symptom-d-o-a-treadmill
It should be noted that I've done a few tests and the red LED indicating power to the board is constantly turned on, but I am getting a flashing green light on one spot along the circuit board that follows exactly the frequency of the powering on and off of the machine itself.
