PaceMaster Silver Select Error
Hi Everyone,
New here, hoping someone can help me out. We recently moved and I put back together my PaceMaster Silver Select treadmill but it isn't working now. When its plugged in and I attach the magnet key I get a red light that lights up in the motor housing. There are 3 red warning lighhts, its the middle one. Anyone have any idea what the heck that means? I don't even know where to begin? Help. Thanks in advance!
