Freemotion treadmill XTR runs for approx 4 min...It comes to a stop...and then starts back up again.
                    I have a fremotion and when is running each 4 min...it comes to stop but then start back up again within raise to stop...this is cyclic...Do you have any idea what kind of problem is this...?
If the entire front roller continues to spin then you will need to adjust the running belt.
This should help you troubleshoot exactly what is wrong with your treadmill, and remember to lube your Running Belt & Deck every 6 months.
Recently the local technician in Veracruz, Mex comes with other console with the other label...so ..he tested and the problems goes....he says that the problem is the console but in Mexico I don't where can I get a console similar as spare parts. Do you know where can I get this kind of console.
The motor and the belt are ok,
