NordicTrack 25046 Console partially works - motor & console buttons do not
                    I have a used NordicTrack 25046.3 (2.5 y/o).  Recently moved it to a different location and had to remove the console.  Reassembled and the unit started right up and worked correctly.  Went to start it a few days later and the screen works - workout timer/ifit/settings/etc. however the motor will not move the belt and the speed & incline buttons do not work.  I took the console off and all wire appear to be connected and intact.  Any advice for repair?
The data cable is fine all the way up to the MCB via a volt meter.
all cables are clean and checked with volt meter?
You have a new MCB and the questions above are yes then it sounds like your console is going
