Livestrong LS 8.0 walking belt slipping
Hi everyone!
New member here. Bought a Livestrong LS8.0 treadmill a couple weeks ago. It needed lubrication (even said so on the dash) so I did, using 100% silicone, as many have suggested. Now, when I would run on it prior to lubing, it would squeak, and the squeaking would come from the motor. So I also put a little bit of lube on the drive belt and the inner ring of the pulley (on the front roller). Belt started really slipping immediately as I got on after that.
Since then I learned that maybe I should not have lubed the drive belt. So I cleaned it, multiple times, very thoroughly with rubbing alcohol and de-greaser, so I think at this point it should be fine. The drive belt is also quite tight and does not look damaged at all. And the belt is slipping less, but it still is slipping. It's more of a wobble than a full slip, but it happens everytime I step on it.
It works perfectly on higher inclines. Running up the hill feels as good as ever. But the minute I bring the incline down to flat, it starts wobbling again.
So looks like the belt started wobbling after lubrication. I have since cleaned the deck and lubed the belt multiple times, but still no avail.
What could be wrong with it? I find it strange that something happened to the walking belt after I lubed it, but maybe something did.
Any help is appreciated. Thank you!
  • Hello and good morning!
    You might just need to adjust the tension! Check out these videos for direction!
    https://www.treadmilldoctor.com/walking-belt-adjustment
  • Hello :)
    Thank you for your response. Oh yeah, I tried adjust the tension, centering it more, but it still is slipping. I never overtightened it, but somehow I dont think that would fix the problem.
  • What is your serial number?
  • MY RUNNING BELT STOPS WHEN I STEP ON IT
    B) If yes then it could be a weak Drive Motor or bad Motor Controller.
    B) If just the pulley on the front roller continues to spin, then you will need to replace the entire front roller.
