NordicTrack 2450 Speed Limit Decline
                    Hello,
Is it possible to readjust or delete the factory settings for limited speed when the belt is in declination?
These are a
12.9 km/h to -3%.
13.7 km/h a -2%.
14.0 km/h to -1%.
When you do a route that varies quickly the ascents and descents, this parameter is quite painful.
Thanks
These are a
12.9 km/h to -3%.
13.7 km/h a -2%.
14.0 km/h to -1%.
Thanks
The automatic decline is set up not only as a safety feature, but also to help you work different leg muscles for extra toning and calorie burnout.
No, it is not possible to delete the factory settings - you can only adjust manually during the individual workouts with the OneTouch controls incline button.
For example:
You enter a course, and this one has several false flat, which make the course go very quickly from 0% to -3% then 0% in 3/4 seconds.
Well if your speed is 15km/h, you fall back to 12.9km/h despite the fact that this short period of time did not allow the treadmill to go down.
