Lubed belt a few months ago belt has been stalling since
Hi,
I lubed my treadmill belt about 6 months ago and the belt has been sticking with each step ever since. I'm 100% sure the belt had never been lubed before that point and whatever lube was on there was just the lube that was left over from the factory. I used a silicon based lubricant which from the impression I'm getting from the treadmill community, was a bad idea. I followed some YouTube videos and tightened and centered the belt. It still stalls and I can stop it by putting a foot down on the deck.
Did I ruin the belt?
Here is a link to the lube I used.
https://www.amazon.com/Lube-N-Walk-TL54-Treadmill-Lubrication-Kit/dp/B000VZLCWY/
I would dislike intensely having to tell you to replace both but for sure we are looking at replacing the belt...
https://imgur.com/a/sdbdp1D
It's a Nordictrack C900 Pro.
