Proform 590T console not turning on
Good afternoon, i just recently got an 590t proform treadmill on an auction, it was working no problem to begin with, but once me and my wife tried moving it to the living room it stopped working, when its plugged in i can see the light on the control panel near the motor light up, but the panel on the treadmill doesnt turn on, what could be causing this issue? the treadmill is receiving power, can anyone help me troubleshoot this issue? thank you
It is possible during the move that you pulled a wire loose. Would you be able to check the wiring from the panel to the speed sensor? Just to make sure everything is still plugged in securely?
Do not give up! We sure won't!
You need to test the red wire & the black wire and should have anywhere from 8vdc to 12vdc on those two wires.
If you have that voltage then console is bad.
If you does not have the voltage then the motor controller is bad.
Could it be that the wire harness is bad? because the motor controller has a solid red light on it , maybe is just the cable thats bad
