NordicTrack a2250 - Starts, then immediately stops
I have a NordicTrack a2250 that started acting up. The treadmill starts, then immediately stops. The console looks fine and still acts like the motor is still running.
I did the battery test, and the motor runs fine if I connect directly to a battery.
I think it's the motor control board. But I want to be sure that I am buying the correct part.
Is there anything else I can check to confirm the issue is the motor control board?
Thanks for you help!
Once you've added items to your cart, and you are ready to check out you can put this Discount Code 10OFFJAMES in the Discount box on the check page where you put in your billing and shipping information at. You will see your discount amount applied on the right side of page.
