Horizon GS1050T Control Board Issue
The motor control board has two relays, When pressing start (go button), the relays 'click' rapidly. (Not sure if it's one or both doing it). I replaced both relays, same thing.The drive motor does not run but can be rotated by hand. The red LED does not generate a code but is fairly steady with a slight flicker in tune with the relay clicks. Any help appreciated.
Thanks,
ctg
Thanks,
ctg
Once you've added items to your cart, and you are ready to check out you can put this Discount Code 10OFFJAMES in the Discount box on the check page where you put in your billing and shipping information at. You will see your discount amount applied on the right side of page.
