Finnlo Loxon stressless rear wheels not centered. Sliding off to the right
I've been using this elliptical for 4 years now and the rear wheel started to slide off. I don't know how to fix it and I tried everything except disassembling every screw.
This is how it should look like: https://i.imgur.com/J5C6BkF.png
And here is after sliding off https://i.imgur.com/umHqLtt.jpg you see that the wheels slide to the right and are not centered
Here you can see what I'm talking. https://i.imgur.com/RovZfhX.png The disks marked in green slide off when I put any weight on the right pedal. The elliptical is still usable but I'm afraid the tear will destroy it even further.
I disassembled the pedals and almost everything but after removing the red bolt the wheels won't bulge. I also tried to make changes to the tension of the cable but it doesn't change a dime (the cable goes over the left wheel - the technical drawing is wrong, the yellow part should be on the right)
Even If I take the bolt, the screw will not move an inch. https://i.imgur.com/tmPxGUJ.png
Any help!?
Any help!?
