Replace endcap on Proform 745CS
Hello - I'm looking for the instructions on how to remove/replace the endcap on a Proform 745CS. This site is the only place I found the part. It's no longer available from sears... Before I purchase, I want to see how difficult it will be.
//Brew
  • All you do is remove rear roller bolts and then the screws that hold endcap in place. Then you reverse the steps to install it.Click on this link first https://www.treadmilldoctor.com/carts/discounts/WMKW8IMhjhMhHZnAJCzIdg then type in part # or model # into the search window. Then when you see your part you can add that to your cart. Then once you go to checkout you will see your Parts 10% discount on the right side when entering you bill to and ship to address for your order.
