walking belt
Recently when you walk on the platform, the belt does these really quick hesitations.. also started noticing black fluffy stuff under and out the back of the platform. Thought it might be the drive belt.. Checked it and it looks fine. rollers are adjusted according to manual. Could it be the walking belt??? Rollers??? help!!! My son is having a fit he can't use it! THe treadmill is a Proform crosswalk 405E.
  • Could very well be a loose or worn running belt, or a loose drive belt . Also it may be a front roller pulley has broken loose. Attach is some helpful things you can try.
  • thank you...I will try these things...
  • Good luck
