Nordictrack treadmill Error Code p0
edited November 2018 in Treadmill Problems
Trying to work on a Nordictrack treadmill and plug in machine turn on and get an error code p0. Please advise...
  • Normally when you get the "PO" code on your treadmill it is caused because the key was in the machine (like it was running) and it lost power. If you were using it and the power went out, that is what caused it.
    To clear it you can put the key in like you're going to use it, then remove the key, then unplug the machine. Let it sit for about a minute, then plug it back in and insert the key. It should come back up as normal then.
    If there was no power loss or you cannot get the PO to go away, there is a problem with the controller or console and you will need to have a technician come take a look at the machine to figure out what exactly is causing this to happen.
