Apparently silicone belt lube will result in damage on old Pacemaster Pro Plus
I bought a used Pacemaster Pro Plus. It's a bit dirty and neglected, but in perfect running condition. There's some debris under the belt, and it seems as though it would be a good idea to clean it out. However, the user manual says that the belt is maintenance free, and that using any kind of lubrication ("especially silicone") will result in damage.
Is it safe to clean under a maintenance free belt?
After I clean, is there some other kind of lube that would be appropriate for this machine?
