Nordictrack c2000
I bought this used. Worked perfect for demonstration. Get it home. Ran for about 15 seconds and dead. Acts like it has no power. I took cover off and have the solid red light. Performed reset as instructed in manual. Im at a loss of what to do next.
the solid red light is good - that means that part is getting the correct voltage...
here are a few things you can check when you do not have power:
please check to make sure all wires are securely plugged in inside
If you do not have the voltage then the motor controller is bad ( which we know you are getting voltage as the red light is on)
you might just need to replace the wires!
