Proform Crosswalk Fit 415 issue - powers on but nothing else
I have a Proform Crosswalk Fit 415 (Model Number 831.24853.0). The unit does power on - the display beeps once and lights up when the magnetic safety key is applied - but no response when pressing any of the buttons. I do notice that if I place my fingers on the silver "pulse" readers, the display will show the heart rate but none of the other buttons work (incline up/down, start/stop, speed, etc).
I have unplugged/reset, all the ususal stuff with the same result. Looking for suggestions on what to check next.
If it turns out to be the controller board, I also would like to know which part number to use. The controller board is imprinted with MC2100LT REV ICON 2006. There is also a sticker on the side of the transformer mounted to the board which reads MC2100LT-12 226706, and there is a green sticker on the side of the aluminum heatsink which has MC2100LT-12. I tried looking this part up on SearsDirect and got a completely different part number which is 357333, now replaced by 405825.
Thanks!
  • You can check the wires for 8-12v!
    we have an updated MC-2100 that works better than the original
  • Thanks for the response. Can you advise which wires to check for voltage, or location on the circuit board? Can you also provide information on the updated MC-2100 please?
  • from the board - test the red wire & the black wire.
  • I checked the voltage. At the controller board without the connector I get 18v. When I plug the connector in I get 17.5v.
  • You should checking for voltage at the upper console on the 8 pin connector.
  • Correct, the 8-pin connector, red and black wires. It's the same cable, I'm just checking it where it plugs into the controller board. I did check both ends though - still 17.5v.
  • And you got 17.5vdc?
  • Then you have a bad console
  • Yes - 17.5vdc. Is there anything else I should check on the console itself? I did disconnect/reconnect the connector just to make sure it was seated properly.
  • Nope, its a console issue. That console is out of stock at this time.
