PROFORM 835QT Stops under load, then Restarts.
edited January 6 in Treadmill Problems
Treadmill runs with no load, stops with load. When it stops, the motor and walking belt stop.
I have already replaced the walking belt and lubed it. Not it.
The motor belt isn't tight or loose.
I have tested the motor flywheel with a foreign object with downward pressure and it stops, doesn't slow down.
I checked the motor brush and check for demagnetization, looks good.
Do I need a new motor or controller? uggh... Both are $200 for this machine.
  • can you test the red wire & the black wire?
  • Hi there
    Sounds like I have a similar issue. I can try to measure this VDC. Shall I do it with the belt running or stopped?
  • While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses.
    There is a chance a breaker may have shorted open and not tripped. Please test these components individually and remember you want a closed circuit on all of them
