Parts for older NordicTrack CX 925 Elliptical
I found this machine at local thrift shop. Console needs work - replacement parts.
Not sure where the Model Number would be on this machine....any ideas?
  • model numbers are usually located on stickers near the bottom of the frame or on the underside of the machine
    you could also call and talk to Steve - he has over 30 years working with treadmills and can help!
    800-750-4766
  • There is not a sticker on the bottom of this elliptical machine that I can find. Doing some research, I believe the machine is a Model NEL07940. The battery compartment has alot of corrosion. I'm thinking I will need to replace the whole compartment unit if there are still parts available for this model.
    Thanks!
