Shuts down during workout
I have a NordicTrack A2750 Pro, model #NTL01009.1 I purchased used. Belt was tracking right, adjusted according to manual instructions. First use was ok, no problems. I'm a first time treadmill user, so I started off at speed 1 for the first day. Seemed slow, so 2nd day I went to speed 2. That went ok, but day 3 the belt started shutting down after 45 to 90 seconds of use. Console and fan stayed on, unit would restart ok after 5 seconds when I pushed the start button. Every 45 to 90 seconds it happened again. If I start it up without walking on it, it runs fine without shutting down. Now I'm a very heavy guy (400 lbs +, which is why I got the thing in the first place), so I'm suspecting an overload issue. Anything I can do?
  • Sounds like its a problem with the belt & deck and a lack of lubrication, you may want to lube the deck. Also the treadmill can not handle anything over 350lbs.
